Oil Leak Thanet I Can't Locate
Fossy313
, Apr 13 2014 06:55 PM
8 replies to this topic
Posted 13 April 2014 - 06:55 PM
Hi guys, I have an oil leak which I found today which I just can't seem to locate, I haven't gone as far as ditching the coolant or anything yet and taking the rad out because I just don't have the time, the weird thing is it seems to be coming from the front of the engine somewhere, it's all over the inner part of the starter motor and the wiring that connects to what I think is the crankshaft position sensor, like I said it's not a great deal but has built up over time, although I haven't checked the oil for a few months because I have been away and haven't driven it as much.
Any ideas? I did have a photo but can't seem to upload it
Posted 13 April 2014 - 06:56 PM
Can't upload it I'm on my phone
Edited by Fossy313, 13 April 2014 - 07:05 PM.
Posted 13 April 2014 - 07:00 PM
Oil pressure sensor? Thats where mine was leaking from
Edited by cragthybob, 13 April 2014 - 07:00 PM.
Posted 13 April 2014 - 07:05 PM
Worth a look I guess mate, maybe the sensor I think isn't the crankshaft one and it's the oil pressure, which would explain why the wire is soaked because it's running down that...where is the oil pressure sensor located mate can't seem to see it's location in the workshop manual, I'm just going by that and the one sensor that basically goes up near the starter motor is the crankshaft position sensor
Edited by Fossy313, 13 April 2014 - 07:09 PM.
Posted 14 April 2014 - 06:18 AM
Maybe the oil capillary pipe from front of the block down to the filter housing? Very weak joint on my injection which I replaced with a better one years ago.
Posted 14 April 2014 - 09:08 AM
I think its a rad off and have a nose around case I take it? Lol, I didn't my ow there was an oil pipe to the filter I thought it just went straight onto the block or am I getting mixed up?
Edited by Fossy313, 14 April 2014 - 09:11 AM.
Posted 14 April 2014 - 02:07 PM
Might be your dipsyick vibrates up and comes from there .I have fitted aspring to mine with a hook on that holds it down.
Posted 14 April 2014 - 07:01 PM
Sorry, didn't realise yours was a MPi. You are correct, there is no pipe on the MPi.
