Fixing Tachometer
electrical engine
9 replies to this topic
#1 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 15 April 2014 - 12:48 AM
Hi,
I bought a 1992 rover mini city 998cc and it came a tachometer but hasn't worked as far as I know, it has 2 connections coming out of the back of the dial but I don't know where they are supposed to go and connect to, anyone help me get this working?
Will
#2 the beasts
the beasts
  • 80 posts
Posted 15 April 2014 - 01:26 AM
earth and to the coil , but wait for a better answer from someone, a pic would help the next person.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 April 2014 - 03:38 AM
Indeed.  A picture will help quite a bit.  There were at least two types of Smiths tachometers used over the years.  A picture will clarify which you are trying to wire up.
#4 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 15 April 2014 - 03:43 AM
I will get a picture tomorrow when I can, it's not a smiths tachometer, it came attached to the mini but I don't think it's original
#5 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 15 April 2014 - 05:11 PM
There are the pics, there is a free port on the ignition coil and a few loose wires around it but connecting the loose wires doesn't seem to work
#6 Gremlin
Gremlin
  • 2,142 posts
Posted 15 April 2014 - 05:21 PM
You need to trace that white wire with the black trace and connect it to the coil - terminal, then it should work as the light green/orange should be soldered in to the ignition controlled loom
#7 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 15 April 2014 - 10:58 PM
I connected the black and white wire to the ignition coil but it just stopped the car from starting and then when I disconnected it the car starts straight away
#8 Gremlin
Gremlin
  • 2,142 posts
Posted 15 April 2014 - 11:24 PM
to which terminal on the coil?
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 April 2014 - 12:14 PM
I know where you are going with that question but there is a bigger problem.  If you connect the white/black wire to the wrong coil terminal (coil(+)) the tach will not work.  If (as WHarding is reporting)  the engine will not start with the white/black wire connected to a coil terminal (either terminal) there is a bigger problem.  This indicates that the white/black wire has a short to earth OR the tach has an internal short.
My suggestion for a test is to disconnect the white/black wire at both ends. Temporarily run a new wire (outside the loom) from the back of the tach to the coil (-) terminal.  If the engine will start with the external wire connected, there is a short in the white/black wire and you need to buy a new length of white/black and run it neatly between the gauge and coil.  If instead the engine still refuses to start until you disconnect the external wire, the tach has a short circuit and needs repair or replacement.
Before adding a new white/black wire (if necessary) make an additional check.  Look carefully at the wiring around the coil (sorry... I cannot tell from your picture).  Some looms include two white/black wires.  When points are fitted to the distributor, a short white/black wire goes from coil (-) to the distributor. The second white/black goes from coil (-) to the tach.  If an aftermarket electronic ignition has been fitted, that can leave (3) possible white/black wire ends in the vicinity of the coil.  Make sure (using a multimeter) that the white/black you connected to coil (-) is the same white/black you have connected to the back of the tach.  At the coil... locate any remaining white/black wire ends and tape them up so the cannot touch earth.
#10 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 11 May 2014 - 11:55 PM
Thanks very much Doug for so much detail, the wires on my car are... well... lets say not good so its probably dodgy wiring as i have loose wires all over the place. I will keep trying to get this working
Will
Also tagged with one or more of these keywords: electrical, engine
