998 auto 1990.
As mentioned on a previous thread, I've got low (50psi) compression on cylinder 1. It was running fine just a bit lumpy when stationary with drive selected but otherwise fine. No real lack of performance.
I changed HG hoping hat was the issue but to no avail. Head and valve seats look ok
I adjusted valve clearance to 12 thou and re torqued head bolts after 1st heat cycle
A new problem has occurred though. Drove to work ok. Drove home ok. Got back in 15 min later. Still hot. Just turning over without starting.
I did get it started eventually but it took a long crank and reluctantly just about started. I drove round he block and stopped engine. Same problem on starting.
The plugs are a healthy colour and I've re checked the valve clearances.
Could it be this that's causing my problem? I found it more difficult than I anticipated to get a consistent gap on all rockers.
The only other thing I did was change the manifold gasket.
starting when cold is fine.
Jim.
Edited to remove my waffle.
Edited by jime17, 16 April 2014 - 06:38 AM.
