Got spring compressors yes, tracking gear no, just going to measure it up like i did with the mini, they just thread on. Can always get them to do the tracking before re-test.
you don't need a spring compressor.
Not if i unbolt both shock absorbers no, but will need them to do a single side. Only have 1 jack at the moment.
you can do just one side at a time, jack it up, unbolt the shock and then pull the spring out.
Yeah thats how i ended up doing it. Just had my brother pull the drum down slightly to get the new one in.
They wanted £170 for that, took me about 15 minutes...
Update on the situation
All of the work has now been sorted, so new track rod end, roll bar bushes and rear springs. (What it failed on)
However
They can't re-test it till Tuesday.
In this aspect the car is roadworthy, as it only failed on these points, and will pass because they have now been fixed.
Now where do i stand in regards to driving a car which is apparently unfit for the road when it is actually fit for the road now?
Edited by Yams, 18 April 2014 - 05:34 PM.
