i'm trying to get rid of the rust on my mini and have sanded past all of that flakey red stuff and got to that dimpley black stuff is it ok at that stage to paint over it with a zinc primer or does it need some other treatment to banish it for good?
em rust
jonny blaze
, Jun 13 2006 01:42 AM
6 replies to this topic
Posted 13 June 2006 - 01:42 AM
Posted 13 June 2006 - 06:40 AM
The only sure way to get rid of rust is to cut it out... but failing that I would use some rust treatment and the a zinc primer.
Posted 13 June 2006 - 07:02 AM
The black stuff is still rust, you really want to get rid of it all and back to bare shiny metal, If you dont the rust will come back through.
This is why it is said that you cut the metal out and replace it.. this is true but only if you can not clean up the metal so it is 100% shiny again. I.e. no black dimples.
A dremmel style multi tool (£10 ) from homebase, B+Q etc is excellent for this
Posted 13 June 2006 - 12:44 PM
cheers guys, don't think i'll be cutting it out as there isn't that much of it but still want to get rid of it for good, i'm gonna try and get it back to shiny metal, thanks again
Posted 17 June 2006 - 05:41 PM
Small sandblaster works a treat on these small areas.
Posted 17 June 2006 - 05:45 PM
i find a power file works well
been doing my roof gutters today :'(
Posted 21 June 2006 - 09:18 PM
2 things, Coca Cola and some tin foil.
soak in coke, and rub with tin foil, off comes the rust. sorted!!!!
