Mini sidewalk started having trouble starting stops on own no spark at plugs tried all tests started to day after leaving 4 weeks revved op seamed ok let tick over cut out will not start petrol pump ok. ? Can you help
Mini Won't Start
dbrill
, Apr 21 2014 07:42 PM
2 replies to this topic
Posted 21 April 2014 - 07:42 PM
Posted 21 April 2014 - 09:26 PM
Moved to injection section
FS
FS
Posted 21 April 2014 - 09:35 PM
You wrote tried all tests...what have you tried please?
Low voltage connection to coil?
Coil (measure impedance with multimeter)?
Checked distributor cap?
Rotor arm?
Plug leads?
I would be checking all of these as lack of routine maintenance of the last three or deterioration of the wiring or coil could all be implicated.
These are the simplest to start with dbrill.
Once we know what you have checked I am sure the members will give their feedback
FS
Rotor arm?
Plug leads?
FS
