Gunson Emissions Analyser: Setting Up A Weber
8 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 23 April 2014 - 07:17 PM
how do.
hopefully when i finally get  the engine in the car I'll be temporarily setting up the weber with a gunson gas analyser, the analyser reads the CO2 level as a percentage, what CO2 level would i need to be aiming for? 1380-fast road cam-BVH-10.5:1 etc.
also as a side note when i start her up should i set the idle to around 2,000RPM  for 20mins to bed the cam in and also should i adjust the idle until running in is complete?
cheers,
bear.
#2 Dusky
Dusky
  • 5,322 posts
Posted 23 April 2014 - 07:41 PM
You should run in the cam for 20 minutes, after that you can change idle.
Dont think you are supposed to idle th eengine at 2000 rpm though, I think you need to keep altering the revs between like 2K and 2100..
#3 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 23 April 2014 - 07:56 PM
cheers pal, when am using the car on the road while running in, should i set the idle around 1200rpm?
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 April 2014 - 08:40 PM
Depends what cam you decide will dictate what idle you end up with, your CO meter will set the idle mixture and that will have a maximun reading acording year of the vehicle for the MOT. For jetting then there are starting points but to get your weber jetted correctly then a rolling road session is the next step.
#5 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 23 April 2014 - 08:49 PM
wont be able to RR untill the engine is run in. weber is jetted as a starting point. what idle should i expect with a 276? ignoring MOT regs, what should i set the CO2 as?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 April 2014 - 09:31 PM
My 1330 has a 276 and idles round about a thousand revs, my CO at idle is 3.0%
#7 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 23 April 2014 - 10:27 PM
cheers  pal.
i heard that am not allowed to let the engine run at normal idle engine speed during the run in process, is this right.
thanks again,
bear.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 April 2014 - 09:55 AM
You need to run the cam/followers in when first started, engine speed 2000rpm for about 15mins, otherwise you;ll have issues with the camshaft/followers.
#9 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 24 April 2014 - 01:32 PM
I run mine in at a minimum of 2000 (usually 2500) for 20-odd minutes then changes the oil & filter.
