Whirring From Timing Chain Area!?
23 replies to this topic
#16 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 April 2014 - 07:44 PM
 @Tiger The tensioner DOES NOT run correctly against the duplex chain, and so is NOT used.
Ask AC Dodd both he and I beg to differ.
#17 sledgehammer
sledgehammer
  • 3,100 posts
Posted 26 April 2014 - 08:18 PM
I have seen wide tensioners made for the duplex chains - & also seen std tensioners run on duplex - which I suspect wear quickly -
because the outer links on the chains miss the nylon totally
can't see why the wider ones wouldn't work - esp now nylon is much better than the 60 / 70's
we use nylon chain tensioners at work (asa 60) - with hundreds of kilo's force on them - they last well
Edited by sledgehammer, 26 April 2014 - 08:19 PM.
#18 Gremlin
Gremlin
  • 2,142 posts
Posted 26 April 2014 - 08:52 PM
I was talking to ACDodd today and he said that he never builds an engine without a tensioner - simplex or duplex, and always strongly advises people to put tensioners on their engines
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 April 2014 - 09:03 PM
When chains stretch the obvious is a bit of noise but perfrmance is seriously efffected on cam and ignition timing.
#20 ACDodd
ACDodd
  • Mini Docs
  • 2,752 posts
Posted 26 April 2014 - 09:34 PM
Tensioner all the way.
AC
#21 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 April 2014 - 12:36 AM
Sorry to differ a bit, but chains don't stretch, they wear, together with the sprockets.
#22 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 April 2014 - 06:38 PM
So they wear and therefore there overhaul length goes beyond specifacation, chicken and the egg ! lol
But side plates do in fact stretch I have a chain here off a superbike which the sideplates stretched before they broke
#23 sledgehammer
sledgehammer
  • 3,100 posts
Posted 27 April 2014 - 11:05 PM
Chains definitely stretch - but most are now pre-stretched
the machinery I produce for a living , is calibrated to accommodate stretch
even with pre stretched chain , its asa-60 etc - and still stretches when under load
timing chain is short on a series, so stretch will be minimal , but still a factor esp with sprocket bedding in added on
longer timing chain stretch on some engines will be a problem later on
#24 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 28 April 2014 - 02:50 AM
It's an interesting topic amongst bikers :-) And with bikes producing huge outputs there is the possibility of mechanical damage but it's unlikely - I can't even get 130 HP on the ground in 3rd gear, on a dry road a 500Kg bike (600 + Kg with me on it) will spin it's back tyre., just guessing but perhaps your chain was off a bike engined conversion?
Anyhow, back to the plot, a chain in normal usage will not stretch, it will wear it's rollers, pins and bushes and appear to get longer, but won't stretch :-)
And more pertinent to this discussion, the usage of a tensioner ensures that correct chain to sprocket geometry is maintained, reducing sprocket tooth and flank wear on chain pickup.
A mini cam chain is very lightly loaded, particularly a duplex - take a look at a british bike primary chain - they are tiny in comparison and transmit 50 horsepower with very high shock loadings and reversals.
