Is My Mini Possessed By The Devil
5 replies to this topic
#1 kev fletcher
kev fletcher
  • 12 posts
Posted 27 April 2014 - 08:53 AM
You might remember my last post where my 1996 spi mini had a charge problem that involved changing 3 alternators and 2 new batteries this was eventually tracked down to a fuse box that let voltage out but not amps.
Well my latest problem was a weeping sump plug, it turns out the threads were goosed in the sump so lifted the engine out and took it to Jon speed minis who fitted a insert and a brilliant. Job they did and only charged £25 anyway while refitting the engine i noticed the brake line was weeping slightly so replaced that and the soggy dampers at the front.
So whats the problem now, well when the engine went back in i started up and it went straight to about 4000 revs and ran lumpy i have checked the throttle cable and its not catching all hoses es have been put back so any ideas as to why the engine is reving so high  also i have seen post about fault, code reading on a spi where would you plug your code reader in ?
Thanks in advance
Kev fletcher
#2 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 27 April 2014 - 09:21 AM
my first thoughts would be an air leak, as you've had the manifolds etc. off when you removed the engine. So check for leaks would be the first thing
#3 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 27 April 2014 - 10:38 AM
What rob says about the leak...only other thing is double check ur butterfly isn't catching...that was a problem with me.....welcome to my world mate, I have had over two years of problems with my mini and they are still racking up...your not alone, believe me
#4 FlyingScot
FlyingScot
  • 2,661 posts
Posted 27 April 2014 - 12:51 PM
On you last point OP the code reader plugs into a 3 pin white AMP connector located on the bulkhead area around the brake servo. However this presumes you have a suitable code reader to use - generic no good for this application.
FS
#5 humph
humph
    How bad can it Be?
  • 1,065 posts
Posted 27 April 2014 - 03:30 PM
FS
Agreed here. When I had similar problems with my SPI none of my local garages could get my car to communicate with their kit. A sykes pickavant has sorted this. My problem was much more complex than yours and ended up being stepper motor drivers within the ECU, I would go with the vac leaks the guys above suggest.
I'm sure you've seen it but Sprockets thread here is very good
http://www.theminifo...oint-injection/
#6 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 28 April 2014 - 08:10 AM
FS
well worth reading
