??130Bhp??
Posted 14 June 2006 - 07:39 PM
power? I would want to run a T2 turbo with custom manifold, would the turbo be ok for
this kind of power? Also what sort of price would I be looking at to build a 120-130bhp metro
turbo engine?
Posted 14 June 2006 - 07:57 PM
A standard Metro turbo engine with a lower C/R head will be good enough for what your after.
MW
Posted 14 June 2006 - 08:27 PM
(copper)dont know what head tho? What would need to be done to the head?
Would straight cut gears be necessary? How about an LSD?
Posted 14 June 2006 - 10:33 PM
I was thning of a T2 turbo on custom stainless manifold, fast road cam, and race gaskets
I think standard good quality gaskets would be suffice to be honest.
For a cam you'll find almost everyone will point you in the direction of the Avonbar Phase 2 turbo cam, which is very similar to the 266 and standard MG metro (not turbo) cam, but has a few extra benefits for a turbocharged engine. Oh and dont forget a turbo oil pump!!
As for a head, for the sort of power you are looking at Morspeeds Stage 2 turbo head would be ideal and is very competetively priced at £150-£200 (cant remember exactly what it costs)
You shouldnt need an LSD at that sort of power i wouldnt imagine but a twin pin diff or at tthe very least a hardened diff pin will be needed.
I cant afford to run a s/c gear box so i am just rebuilding my helical box, although in an ideal world i would have them.
Good luck with the build
Dan
Posted 15 June 2006 - 07:17 AM
Dan
Pretty much agree with all of that, the hellical box will be fine, it's just the ratios are a bit C**p. With 130bhp you'll be verging on the limit of the hellical drops, but if in good condition they'll last long enough.
I wouldn't bother making your own manifod either, too many people have tried and failed. Unless you know a lot about the subject it's best to buy the Mirage Motorsport one or use the metro one.
Wil
Posted 15 June 2006 - 09:13 AM
Posted 15 June 2006 - 12:30 PM
Of course it's possible, but don't expect to get it right first time. i don't expect Mirage or Jan Speed (or even Austin Rover) did.
Posted 15 June 2006 - 01:18 PM
has anyone tryed this?
cheers
josh
Posted 15 June 2006 - 01:30 PM
Also if you dont want to cut your bulkhead fit the mirage manifold kit with T2 turbo as the metro turbo manifold and T3 turbo will not fit without bulkhead modifications.
Dan
Posted 15 June 2006 - 01:58 PM
couldnt u water cool the manifold with a water jacket or somthing?
cheers
josh
What's that saying about cracking an egg? are you insane, do you know how hot they get?
would making your own manifold not have an effect on the air flow however? as wihout a flow bench id imagine it would be quite difficult to optimise a manifold deign for greatest airflow...... or i may just be talkin rubbish.
Dan
A good manifold design will of course reep rewards, however it is less important on a turbocharged car. Look at the Mirage manifold for instance, it has been shown to give good power, but it is a poor design as far as flow goes.
Posted 15 June 2006 - 03:19 PM
Ive got a long way to go, and a short time to get there *ahem - smokey and the banit in my head now* but we'll see.
The welding is very shocking, id rather it not crack but it was a bit of a pig to weld as its been sat outside for so long.
Heres a couple of pics, like will said its prob not gonna be right first time. but you dont know till you try! Ive still got the T3 as backup
Dave
Posted 15 June 2006 - 04:49 PM
Hey Mighty Mini, who cares what it look likes as long as it can take a beasting with a hammer (not an engineering practise common to anyone other than me) or you could use exhaust rap, keep everything else nice and cool..... cooler at least.
Yeti
Posted 15 June 2006 - 10:50 PM
Fitting an exhaust wrap will not keep things cooler, infact it will do just the opposite.
Phil.
Posted 16 June 2006 - 02:02 AM
i have been thinking about this while i was at work, and im scrapping the above manifold as of what i read on your posts @ turbomini's.
Im currently stuck, and might need some inspiration on how to manufacture a decent maifold for my TD02 Turbo. Any suggestions? I was going to look around for someone to help fabricate a manifold for it, as im sure its worth paying for if its just going to crack.
Not long to build an engine and get it run in for BH2N, so im really pushing for ideas.
I saw mini1071's janspeed style setup and would like to do that idea. but my turbo is a litytle awkward shaped.
Dave
Posted 16 June 2006 - 06:56 AM
