Right while im sanding and stripping the pick up, i noticed the bottom of my doors stick out something silly.
[attachment=17001:attachment]
Any idea how to fix this? my only thinking is to get it so the bottom fits and cut amd bend the window frame..... is that alittle OTT?
Yeti
Doors not fitting correctly!
Yeti
, Jun 15 2006 07:54 PM
2 replies to this topic
Posted 15 June 2006 - 07:54 PM
Posted 15 June 2006 - 07:58 PM
u can jus bend the bottom bit, easier than re fitting and bending the window part, and it wont snap or anything,
easy to do, i did it on mine, while it is attached and open grab the corner and push while pulling back on the rest of the door
Posted 15 June 2006 - 08:22 PM
right i know the reason and its not a two minute fix, but i bet if you get a jack and lift the floor slightly in the middile of the sill the door will fit into the hole much better, reason is the sill/innersill have proberly been replaced at somepoint and the pickup has lost stome strength
dave
dave
