Uh oh!
We done the last few bits on building the engine tonight, and noticed a bolt for the top engine steady is still in the block!!
there are 2 holes, its the one at the back. is there what can i do?
Do i have to drill and tap it, its very close to the water pocket!
HELP!
TA
mark
Engine steady stud
screech
, Jun 15 2006 10:29 PM
11 replies to this topic
Posted 15 June 2006 - 10:29 PM
Posted 15 June 2006 - 10:40 PM
there that close to the water jacket you wouldnt belave it lol.....be very carefull if you drilling it,might be worth helicoiling it once youve drill it out.least there nout speical like hardend steel there only mild steel just make sure you have a steady hand and a good sharp pilot drill 1st....good luck are kid !!!
Posted 15 June 2006 - 10:58 PM
DSN (and a few others) do repair kits. It's basically a new bracket that fixes onto other bolts. They aren't that cheap mind! (but a lot cheaper than an engine rebuild!)
Posted 15 June 2006 - 11:05 PM
Same problem here!
Only thou I have 2 stuck in my block, and its still in the car
Just going to bodhge it up for MOT, as I have a new engine coming in the next month or so!
Posted 16 June 2006 - 12:58 AM
Yeah I got one of those kits for mine from MiniSpares.
Posted 16 June 2006 - 04:57 AM
Think I have one kicking around which is used, if you need I'll hunt it out..
Posted 16 June 2006 - 06:31 AM
i have one of them kits
dave
dave
Posted 16 June 2006 - 02:36 PM
PM sent dave ta
Posted 16 June 2006 - 06:26 PM
Definitely use the repair kits for this, it's almost impossible to remove either of the two engine steady rod bolts once they snap without taking the engine out and sticking the block in the milling machine. There are several different kits available, you need to choose the correct one depending on which bolt has snapped and whether there is a breather canister fitted or not.
Posted 16 June 2006 - 10:48 PM
Can someone link me to these? i cant find pics of them!
Hopfully the one dave has got is the right one, though i am taking it to dickie, me engineer tomorrow to have a look see what he can do.
Posted 16 June 2006 - 11:28 PM
Well, I should of course scream USE THE #**##****# SEARCH BUTTON because this is not exactly the first time someone's done this (and hence the existance of the repair brackets) but since it is pretty hard to find anything on Mini Spares' site thanks to their useless search engine and since no-one seems to have real catalogues on this site I have given in. Here's a link to them at DSN, bottom of the page. If only one bolt is broken and it's the front one, you have to treat it as if both are broken. You'll understand when you see the diagrams of the brakcets.
DSN
DSN
Posted 19 June 2006 - 08:49 PM
SORTED
drilledand tapped!
drilledand tapped!
