Honda Vtec In A Clubman 1275Gt
9 replies to this topic
#1 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 15 May 2014 - 11:24 AM
Hello fellow Vtec builders. In a couple of weeks time i will be starting my own Vetec build and i am after some advise.
After reading through all the build threads on the other clubman builds i am wondering if it can be done without using a flip front on the car as i really want the front as is.
So can i be done people
Thanks for your help
#2 filski
filski
  • 165 posts
  • Local Club: Essex Mini Club
Posted 15 May 2014 - 11:39 AM
To answer your question is yes you can leave the front as is but you will have to remove the inner wings.
However, the conversion is really not as straightforward as you think. There is literally no space to do any work on the engine if the front is not removable, in order to get the engine in would mean mounting the engine in the subframe first and then lifting the front end over it and attaching it to the car that way. This will cause issues in a way that the probability of you taking engine out of the car more then once will be very likely.
Good luck with the build.
there are heaps of info on this at 16v mini forum mate
#3 R1mini
R1mini
  • 1,387 posts
Posted 15 May 2014 - 12:07 PM
At least you have a fair bit more room in the clubman
David
#4 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 15 May 2014 - 12:30 PM
David
That's what i am hoping and why i really, really want to do it without a flip front
#5 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 15 May 2014 - 12:39 PM
Do you really want to do that to a genuine 1275GT the way the prices are increasing of standard ones?
#6 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 15 May 2014 - 12:46 PM
The car has come to me with an over bored engine, so even though it says GT on the V5 no one really knows if its original or not. At the moment i have a round nose that i have sorted as far as it can go and have always loved the clubman since i owned one back in the 80's.
About 10 years ago i owned an Accord type R and have missed it every day since i sold it so i see this clubby with a Vtec motor to power it as the perfect compromise between the car i love and some serious reliable power.
So to answer your question Hell Yeah
#7 R1mini
R1mini
  • 1,387 posts
Posted 15 May 2014 - 02:05 PM
Done properly the VTEC in a Clubman can look like it's meant to be there.
If I ever done this conversion I would use a round front but it would be extended by 90mm, done properly it can look good
David
#8 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 15 May 2014 - 02:13 PM
David
This is exactly the sort of thing i want to do
#9 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 15 May 2014 - 05:48 PM
Yes it can be done because I am getting there take a look at my build thread and you will see what you need to do.
Would I do it again this way? Hell no its a real pain the ass!!!!
http://www.theminifo...showtopic=66332
Edited by Sleepy Stu, 15 May 2014 - 05:49 PM.
#10 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 16 May 2014 - 05:54 AM
I have read through nearly every thread on the Honda section and when i saw yours it cheered me up as you look like the only one keeping the standard front end.
