I've got a 91 mini with the normal metal type heater. It all works fine. My question is. Is it worth up grading to a later plastic type. Still a single speed one.
Heaters
Mk1Dave
, May 21 2014 10:12 PM
3 replies to this topic
Posted 21 May 2014 - 10:12 PM
Posted 21 May 2014 - 10:57 PM
If it works then why change it? I have a 70's and a 90's mini and both heaters work fine and produce enough heat for my needs :)
Posted 21 May 2014 - 11:03 PM
Just curious if the later ones worked better really. Faster motor better heat direction ect
Posted 21 May 2014 - 11:09 PM
to be honest I dont notice much difference between the outputs. The 70's motor is slightly bigger in size compared to the later ones
