Burning Engine Oil
engine
7 replies to this topic
#1 mikemate
mikemate
  • 23 posts
  • Local Club: West Mids minis
Posted 22 May 2014 - 04:43 PM
Just wondering if there is any advice I've got a new engine I've done 4000 mile, it's my daily and does do stop start traffic
It's a mini 998 that pushing around 65-70 bhp
It's still burning oil and the oil is going black 2 weeks after a oil and filter change
I've been told because it's not standard it will burn oil but how much is my question
Oil pressure is perfect sits at 3/4 of the gauge when driving and no loss in performance
There is no smoke, smell of or signs of oil
The engine has been set up and tuned on a rolling road
It isn't running too rich just wanting some advice
It's not going through oil rapidly but after London to Brighton the weekend it was just above minimum it was aprox about half way between when I left home (done around 500miles)
Been told it could burn oil upto 6000 mile
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 May 2014 - 05:00 PM
If its loosing oil then if its not leaking then its being burnt, odd its going black so quick? what oil are you using. If its built correctly and the clearances are ok then IMO I would not expect it to burn more oil than a std engine. The A series due to its design will always burn a little drop and over 500miles its not using that much by all accounts.
#3 mikemate
mikemate
  • 23 posts
Posted 22 May 2014 - 05:05 PM
It does drop abit like most minis but nothing serious over night like 2-3 drops maximum from that split pin under the bell housing
I am using valvoline 20v50 as told by the builders as they do racing engines and it's what they use
it's a lovely to drive no problems, no smoke and can't smell a thing when following it
I know all minis will burn and leak little just worried as I've forked out how ever much on the build lol
#4 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 22 May 2014 - 05:29 PM
Your crank oil seal has started to fail, rectify it NOW to save the clutch
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 22 May 2014 - 06:00 PM
If the oil is going black after 2 weeks this probably suggests that it is being contaminated. Did the rolling road test for hydrocarbon content? Maybe this will come up in your next mot :lol:  Was the engine run in properly?
#6 mikemate
mikemate
  • 23 posts
Posted 22 May 2014 - 06:04 PM
Cal yeah I had a feeling that was it and
The hydro carbons don't come into play cause of the age of the mini
As afar as I know it was run in properly
They did 100 mile in it for me and they ran the cam in at like 2000rpm for like 15 mins
I did 1000mile not going above 4500rpm
#7 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 23 May 2014 - 07:02 AM
The "not standard" bit has no bearing - it's how the engine has been built -
I'd wait a while yet and see how it settles in. I wouldn't worry about dirty oil to start with during run-in.
#8 mikemate
mikemate
  • 23 posts
Posted 23 May 2014 - 07:17 AM
Thanks it's just I've done 4000 mile thought it would have been okay now
But been told upto 6000
