Ugly External Wheel Balances
27 replies to this topic
#1 campaj1
campaj1
  • 193 posts
  • Local Club: n/a
Posted 23 May 2014 - 12:35 PM
Am aware that this may sound like a bit of an idiot question... if so then I'll get my coat, but here goes...
OK so new tires have been fitted at garage, only they have attached some fat ugly wheel balances to the outside of my pepperpots :shy: . I was therefore wondering:
Do these balances have to be on the outside?
Do you reckon they'll charge me much if I want to move them and if it's feasible?
Cheers, Alex
                      :withstupid:
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 23 May 2014 - 12:51 PM
You can't move them without rebalancing them, you get sticky ones to go behind the spokes close to the outside of the wheel but you'd have to get them rebalanced
#3 adam_93rio
adam_93rio
  • 3,271 posts
Posted 23 May 2014 - 12:52 PM
They look terrible so I always have my wheels balanced on the inside. Somewhere like kwik fit or the usual places like that don't seem to have very experienced tyre fitters and don't tend to know a great deal about it in my experience.
Go to a small independent tyre place with someone with experience and knowledge and they will be able to balance them on the inside
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 May 2014 - 02:35 PM
Most up to date workshops now have wheel balancers which can balance wheel with out weights on the outside
#5 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 23 May 2014 - 03:53 PM
Drives me mad when they put the clip-on weights on alloys .. it damages the lacquer and in a few years you start to get corrosion underneath ...
I always specify stick-ons now .. they don't always like it as it's more work to clean up the wheel to make them stick .. but as I'm paying ... ;D
#6 carbon
carbon
  • 2,590 posts
Posted 23 May 2014 - 04:32 PM
Alex,
With stick-on weights inside the wheel rim check carefully that they are not fouling the brake calipers.
This is unlikely to be a problem with 12 or 13 inch wheels, but I have has this issue when using stick-on weights on 10 inch alloys -  they catch on the 7.5 calipers.
#7 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 23 May 2014 - 04:38 PM
At my placement we ALWAYS use stick on weights on alloys... Doesnt make any difference to be honest
#8 campaj1
campaj1
  • 193 posts
  • Local Club: n/a
Posted 23 May 2014 - 10:34 PM
^^ Right thanks everyone, sounds like it's going back in. Found some pretty noticeable and irritating wheel wobble above 50 this evening too, so they'll be starting again with the balancing anyway... smh!  O_O
Oh, and edit they're 12" "Rover Special Alloys" (Pepperpots to you and me!)
Edited by campaj1, 23 May 2014 - 10:39 PM.
#9 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 24 May 2014 - 09:55 AM
Stick on weights or none!!
Remember you only need weights on the front
#10 Gremlin
Gremlin
  • 2,142 posts
Posted 24 May 2014 - 10:14 AM
Only need weights on the front? Front wheels only? Why?
#11 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 24 May 2014 - 10:16 AM
The rear doesnt give shake etc through the steering.
I work on transit vans, one van had a severe wheel wobble.. We balanced the front wheels and one required 190g of weight.(we didnt put any weight on it) we swapped the front wheels to the rear (which didnt require added weights) and the wheel wobble was gone!
Edited by cal844, 24 May 2014 - 10:20 AM.
#12 adam_93rio
adam_93rio
  • 3,271 posts
Posted 24 May 2014 - 11:10 AM
But having unbalanced wheels on the rear will cause the back end to wobble still
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 24 May 2014 - 11:14 AM
And the bearings to say there goodbuys, who had the thought that back wheels don't need balancing just because you probably wouldn't be able to feel it was good, thats like having a hole in your fuel tank - yeah but you don't notice it driving along!
#14 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 24 May 2014 - 11:17 AM
Yes, all four wheels need to be balanced.
#15 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 24 May 2014 - 11:34 AM
Nonsense!! Every garage i know DONT balance the rear wheels, we have never had a customer come back asking to check rear end wobble!!!!
