need to replace both my A panles. now the wings are removed already as its a removable front. but how do i weld them on next to the door? i am using a gasless mig by the way, i know its less than ideal but its all i have. i'll try to take some pictures so than peolpe can add arrows of where to weld if that helps?
how to weld a panels?
davexdavexdave
, Jun 18 2006 04:48 PM
2 replies to this topic
Posted 18 June 2006 - 04:48 PM
Posted 18 June 2006 - 04:56 PM
I've done a lot of work with gasless mig and it's fine as long as you practice on some scrap before you start. you need to remove the paint/ rust on the lip where the panel meets on the car and on the new a panel. I would also recommend drilling about 4 holes in the lip of the a-panel, one at the top and one at the bottom with the other evenly spaced in between, and weld through them onto the shell. this is called plug welding and will trun out much neater.
Posted 18 June 2006 - 05:01 PM
top stuff much thanks.
