Out of interest, can you / should you, run a in car heater with a blanking sleeve ? Is my memory right, that you use the pump without the by pass hose hole and bung up the the hole in the head ? This is in a 1398cc sprint car that may be road legal. One of the things we used to say was, more water and cooling area the better, sometimes we would run a heater matrix under the wing(never had a stone hole one!).
No replies to this topic
Mini Technical Sections →
Problems, Questions and Technical →
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
