What Filter On A Twin Hs2?
#16
Posted 03 June 2014 - 02:55 PM
Will look into the socks etc toninght when Im home...
#17
Posted 03 June 2014 - 06:46 PM
So wich filter would you get?;) Ive thought about trumpets and socks too, but cant really find good trumpets
Whilst the foam socks are an easy and cheap way out, i would really recommend against fitting them. They have the tendancy to suck themselves in. They do not have any supporting cage and i have seen them get sucked in on wide open throttle. They are a last ditch effort if you really cannot use anything else.
So anything is better than that?
Not that it matters but it's a rover mini 998cc - did they ever get 55BHP out of a carbed one?
Well, it WAS a rover 998 Has a new head, 643 cam,... atm
standard filter housing with kn elements.
http://www.minispare...E1038.aspx|Back to
I wish I could use these but thats the set I bought So dont have an airbox
I was going to use K&N pancake filters with MED stub stacks, but that would cost me £210 all in, which is too expensive, although probably the most efficient option.
Instead, I'm using ram pipes and RamAir sock filters, will cost £40 altogether, much more reasonable. While I'm sure the cheaper sock filters probably would get sucked in, these look quite substantial. Below are links to the products I'm using, there's a picture of them in the twin HS2s picture thread.
Ram pipes: http://www.europaspa...-ram-pipes.html
Foam socks: http://www.ebay.co.u...=item3f2a7fc7bb
Picture is in this thread, post #3 http://www.theminifo...3-pics-of-hs2s/
THey look ace though
#18
Posted 03 June 2014 - 06:53 PM
I very much doubt it is even possible for that amount of filter to be sucked through those ram pipes.
You could even make a little cage out of some open mesh.
#19
Posted 03 June 2014 - 07:16 PM
Do those pipercrosses look cleanable by the way? ( dont have experience with them so..)
#20
Posted 03 June 2014 - 07:30 PM
Do you mean the RamAir ones I linked? If so, I'm fairly sure they are cleanable. Ask miniman24, he actually owns them
#21
Posted 03 June 2014 - 08:40 PM
Ramair is filterable if I read right:D
#22
Posted 03 June 2014 - 08:52 PM
Ah, I didn't see the picture at first because my internet connection isn't very good at the moment.
I'm sure they are cleanable, I think all foam filters are.
#23
Posted 03 June 2014 - 09:03 PM
#24
Posted 04 June 2014 - 02:44 AM
I thought that 998cc coopers had that bhp in the 60'?
Yeah they did on a good day - do you have a 998cc cooper then? maybe I'm getting confused but sticking twin SU's on a 998cc mini won't turn it into cooper spec
#25
Posted 04 June 2014 - 05:45 AM
Got an uprated head , aeg 643 cam( same profile as a 544) Only the crankhaft is still original..
#26
Posted 04 June 2014 - 03:49 PM
#27
Posted 11 June 2014 - 01:34 PM
Bad news ; pipercross filters are fubar ( really, you touch them and they fall apart)
But it seems.that a hs4 cone will fit too on the baseplate( will have a look though) AND under the filters I found 2 ramstacks, so thats good I think?
#28
Posted 11 June 2014 - 09:20 PM
Really are the old twin tin airboxes that good? Below is my current setup with twin carbs and the period airbox, I'm torn between asthetics & performance, my head has always told me to fit twin K&N pancakes wherein my heart (& my eyes) really like the old twin air box, but the design seems so restricted compared to twin K&N pancakes.
#29
Posted 11 June 2014 - 09:32 PM
Ill get 2 k&N cones probably..
#30
Posted 11 June 2014 - 09:35 PM
you could drill holes and use k&n elements?
Drill holes!?! Yikes that tin airbox is probably worth more than my entire car!!!!!!
