Another Clock Electrical Question
Best Answer creakyjaws5533 , 08 June 2014 - 08:02 AM
this? 9d4f6c717fe1e971f37f00e073ac3cb5_zpse8d6
There's just on plug that goes in to the left of the centre dial in this photos which connects it all apart from the tacho Go to the full post
7 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 07 June 2014 - 10:53 PM
To all the mini owners everywhere has anyone got a picture of behind the 3 clocks in a mini 30 i need to see where all the cables go and was hoping someone has a picture that i can look at tomorrow when i want to replace bulbs without taking the clocks off i need to see where the wire goes for the oil pressure light which according to the list below is white and brown. so has anyone got a picture and if you dont know what clocks im on about ive been kind and posted a picture below.
http://www.theminifo...ng-codecolours/
ed3318dac4c4b5088e557f9b562703ad-6.jpg?d
#2 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 08 June 2014 - 08:02 AM   Best Answer
Edited by creakyjaws5533, 08 June 2014 - 08:03 AM.
#3 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 June 2014 - 09:53 AM
Thanm you exactly what i needed :)
#4 cal844
cal844
  • 9,489 posts
  • Local Club: TFMOC
Posted 08 June 2014 - 10:00 AM
The bulbs are '501' bulbs, the same as the side repeater ones
#5 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 June 2014 - 10:26 AM
Thanks ive got bulbs just didn know where they were to replace without taking the clocks out
#6 cal844
cal844
  • 9,489 posts
  • Local Club: TFMOC
Posted 08 June 2014 - 10:34 AM
Yeah, its very fiddly doing it in place!
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 June 2014 - 10:52 AM
doesnt feel that bad as i could feel most of the bulb holders just didnt know where the oil pressure light was im going to see if it is that or not in a minute if not looks like it will have to be fixed with the clocks out
#8 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 June 2014 - 03:37 PM
sorter it is a bit weird the bulb doesnt work just in place so i wired up a bulb in the engine bay to check that current was going through the cable as soon as i have done that it works inside :S
