Wiring Loom Help- Horn (Picture Attached)
Best Answer phil hill , 08 June 2014 - 07:07 PM
The Purple with a black trace is the horn.  If you have a two connector horn then the other connector needs to go to ground, i.e. wire to the car's body.
The straight white wire is for a non-ballast ignition coil, which by the look of your ignition coil i'd say you have a ballasted system therefore the white wire isn't connected to anything.
Phil.
Go to the full post
4 replies to this topic
#1 Kaz Farooq
Kaz Farooq
  • 65 posts
Posted 08 June 2014 - 06:28 PM
Dear all
I have installed a new wiring loom in my 1983 Mini Mayfair. All connections done- lights working etc. I have connected the horn but not working. Haynes say purple/black wire only but there a two male connectors on the back of the horn. I noticed a white female connector connected to nothing- so I tried connecting this to the horn also- no joy.
What is the correct connection for the horn?
What is the white wire for? It is a branch that comes from the same main trunk to the alternator and comes out with the black/white wire that goes into the ignition coil.
See pics for details.
Kaz
#2 phil hill
phil hill
  • 616 posts
Posted 08 June 2014 - 07:07 PM   Best Answer
Phil.
#3 Kaz Farooq
Kaz Farooq
  • 65 posts
Posted 08 June 2014 - 07:42 PM
Thanks Phil.
Could the fact that the horn was not earthed/grounded and simply attached to the Purple/black connector only cause the horn to fail.
Kaz
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 June 2014 - 07:55 PM
Fail as in break? No. It just won't work. Having 12v to both sides won't have hurt it either.
#5 Kaz Farooq
Kaz Farooq
  • 65 posts
Posted 08 June 2014 - 08:06 PM
Fail as in no sound on pushing the stalk.
