No Petrol
Best Answer Moonman , 10 June 2014 - 07:57 PM
Good news cleaned every inch of the carbs and and the float bowls had some grit in the bottom of them so starting no bother now
Go to the full post
Posted 09 June 2014 - 09:39 AM
Posted 09 June 2014 - 09:45 AM
Maybe you've put the dizzy drive in upside down, just rotate the leads for now and if it works you know it's that!!
Also you might have a block in the carb, any fuel in the float bowl?
Edited by coopdog, 09 June 2014 - 09:46 AM.
Posted 09 June 2014 - 10:03 AM
Posted 09 June 2014 - 10:20 AM
Pour a little amount of fuel into the intakes to test if its fuel related, if it starts then inspect the needle valves and see if they are blocked.
Posted 09 June 2014 - 06:45 PM
Edited by Moonman, 09 June 2014 - 06:46 PM.
Posted 09 June 2014 - 07:45 PM
Strip and find out why there is no fuel to the engine from the float bowls, needle valves or blocked jet tubes, check the pumps proving fuel ok in a jampot cranking over
Posted 10 June 2014 - 07:57 PM Best Answer
