Just yesterday i noticed my mini had developed a very strong front brake imbalance. Under braking the car pulls HARD to the right and it actually locked up the front right trying to stop at some lights. I have not had a chance to take a look and will likely be getting to that tomorrow. Before I do I thought i'd get some advice from the experts as to what potential causes may be involved here and what i should look out for.
It may be wrong but my assumptions are that since this occurred so quickly and was not a minor imbalance that slowly developed, there must be a root to this problem and simply re-adjusting the front shoes will not provide a solution. Also, since the front right locked up only under heavy braking i assume the problem is with the left-hand side, which seems to no longer function.
I have searched through the forums and read about seized/leaking brake cylinders and leaking hoses. Other than these issues what else might i expect?
'81 leyland 1000cc
standard drum brakes front and rear
