Clubman Vtec Hopefully Without A Flip Front
21 replies to this topic
#1 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 14 June 2014 - 10:01 PM
Hello all, well today i finally started on my own Vtec build and as the title hoping to do it without useing a flip front.
Probably going about this all wrong as i have started striping the car and have not got any of the bits i need to rebuild it.
this is my car
stripped out the engine bay and interior, removed the front subframe and stripped it down and stuck the car on my home made spit
next step, find and remove the dreaded tin worm
#2 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 15 June 2014 - 06:23 PM
Spun the car upside down, then removed and stripped down the rear subframe, so now have basically a shell to play with.
So now comes the not so nice job of cleaning to underside.
Managed to get one half cleaned
#3 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 15 June 2014 - 08:56 PM
Good luck with your project.
Making me want to start mine sooner rather than later.
#4 GrahamHolland
GrahamHolland
    Just On Tickover
  • 8 posts
Posted 13 August 2014 - 09:06 PM
Will be following. What donor engine/car are you thinking of using?
#5 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 14 June 2015 - 07:03 PM
Well it's been a while but after i cleaned the underside and found all the tin worm my heart fell out of the idea.
#6 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 20 June 2015 - 09:52 PM
#7 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 21 June 2015 - 01:04 PM
#8 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 June 2015 - 01:15 PM
Top tip before you go any further.  Remove the sills you just fitted :lol: You had overfills fitted before, hence the rot.  Fitting more will just rot them out again.
#9 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 21 June 2015 - 01:32 PM
i did not fit the new sills over the rot, all the old outer sill, inner sill and rotten floor was removed before i fitted the new panels look at the last photo in post 5
Edited by blueturbomini, 21 June 2015 - 01:52 PM.
#10 Mini 360
Mini 360
  • 4,933 posts
Posted 21 June 2015 - 01:58 PM
I didn't say you did.  I am saying you have fitted oversills (sills without the holes) which can (and will!) retain moisture in the sills and rot from the inside out.
Edited by Mini 360, 21 June 2015 - 01:58 PM.
#11 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 21 June 2015 - 03:02 PM
understand you now, they are going to be filled with waxoil so should be ok
#12 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 22 June 2015 - 09:21 PM
Also drill some holes where the original ones would have been to let the water out and fill with waxoil like you are going to.
#13 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 05 July 2015 - 08:55 PM
photo up date
#14 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 13 July 2015 - 07:29 PM
Edited by blueturbomini, 13 July 2015 - 07:30 PM.
#15 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 13 July 2015 - 07:31 PM
    Bing (2)
