Buying Mini With No Vin Or Registration
20 replies to this topic
#16 scrog
scrog
  • 640 posts
Posted 17 June 2014 - 12:35 AM
loads of minis have had new front ends and scuttles put on and in many case's vin plates were never replaced
so why should it be a problem
my v5 states on it "made from parts sum or all which may not be new"
and retained it's correct dated plate
have you asked the seller why there is no v5
you never know he might be a honest person
and have a genuin reason
he like hundreds of other mini owners in the past swap shells and parts
why does every one jump to the conclusion it must be stolen
if it's a good shell why scrap it
keep minis on the road not the scrap heap
#17 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 17 June 2014 - 04:35 AM
There has to be a damn good reason for it having no id for you to even consider buying. If we keep buying these cars with no ID, it'll only fuel the theft of our property to be sold on later.
#18 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 17 June 2014 - 06:48 AM
It's not just got no VIN, it's got no V5, no registration mark, nothing.  No data available at all????  There's no way I'd touch it, not a chance.  As for this 'keeping minis on the road' argument, what if it's a mini that's been stolen and stripped for parts and the shell is all that's left?
#19 Carlos W
Carlos W
  • 10,114 posts
Posted 17 June 2014 - 09:23 AM
A Vehicle Identification Number (VIN or chassis number) is required on all vehicles first used on or after 1 August 1980. except those which are
. kit cars
. amateur built vehicles
If a VIN cannot be found the vehicle presenter should be advised of the likely location of the VIN and to thoroughly search for the number with the aid of the registration certificate. If following this action the VIN cannot be found the vehicle presenter should contact the nearest Vehicle Registration Office.
  5. Check that the vehicle is permanently displaying a legible Vehicle Identification Number (this can either be on a VIN plate secured to the vehicle or stamped or etched on the vehicle body or chassis).
  5. a. A Vehicle Identification Number not permanently displayed, incomplete or not legible
Note: Only one VIN is required to be complete and legible.
b. more than one different Vehicle Identification Number displayed.
Note: It is acceptable for a vehicle that has been manufactured as part of a multistage build, (a modification taken place to a vehicle at the manufacture stage before sold as new) to show more than one VIN.
The second and subsequent stage VINs will also be a 17 digit VIN and will be displayed on an additional plate.
When a multistage built vehicle is presented for test the last stage VIN must be used for MOT documentation
#20 scrog
scrog
  • 640 posts
Posted 17 June 2014 - 10:51 AM
Quote from dvla stating you must use old parts to get a date related plate
Any new or replica parts will result in a q reg
So all those that have bought new panels to rebuild a mini should think on
DVLA can only recognise your vehicle as a reconstructed classic vehicle if it meets certain criteria. It must be:
built from genuine period components from more than one vehicle, all over 25 years old and of the same specification as the original vehicle
a true reflection of the marque
The appropriate vehicle owners’ club for the vehicle type (‘marque’) must inspect the vehicle and confirm in writing that it:
has been inspected
is a true reflection of the marque
is comprised of genuine period components all over 25 years old
They must also give manufacture dates for the major components.
DVLA will assign an age-related registration number to the vehicle based on the youngest component used.
New or replica parts
Your vehicle won’t get an age-related registration number if it includes new or replica parts. DVLA will give your vehicle a ‘Q’ prefix registration number. Your vehicle must pass the relevant type approval test to get a ‘Q’ prefix registration number.
#21 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 17 June 2014 - 12:08 PM
That's applicable IF you're building a Mini using a second hand shell. You're cherry-picking quotes out of context.
It's saying that IF you lose your car's ID, you can only get an age-related plate IF you use period parts. If you build from new parts, it'll be Q-plated.
But that's only relevant IF you use your ID. You won't lose your ID if you use new panels or a new shell. New panels or a new shell ARE the correct way to restore and retain the required points to retain the ID.
