Hi,
I'm trying to fit the rear hub with bearings fitted over the spindle on to the drum backplate. Is it meant to be slide on quote easily because I mine go on for about a couple of millimetres before feeling like they are solid. I don't want to force the thing on if its not right. The cause of the problem is that the hole in the centre of the bearing. They are timken bearings and are fully seated.
Any ideas?
Thanks,
Rod
