How wide are the widest lower quarter repair panels I need the lower 6 inches. If none are available I will make my own ...how thick is the steel a mini rear quarter panel made of 1.2 mm ?? Also the rear arches are rotten so I want to chop the arch in the same way as when rubbing the rear arches so what's the most that can be taken out of the mini arches ?? Its going to be running big arches wide wheels and lowered miglia style
How Wide
stumpypower
, Jun 18 2014 05:00 PM
4 replies to this topic
Posted 18 June 2014 - 05:00 PM
Posted 18 June 2014 - 05:12 PM
Pic
Edited by stumpypower, 18 June 2014 - 06:21 PM.
Posted 18 June 2014 - 05:13 PM
from memory I think they are around 5", if you're making your own then its 0.9mm.
Posted 18 June 2014 - 06:17 PM
Thanks mate trying to save the quarter panel if possible
Posted 18 June 2014 - 10:09 PM
Also the dash top rail does it come with the windscreen rubber lip attached it looks like its 1 piece that the bulkhead panel and scuttle panel all meet there to be spot welded together
