Fitting A Manifold With Locating Rings
28 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 05:28 AM
Mine is using those locating rings.
Will be fitting the manifold next week( read today :D) to a CAM 4810 manifold ( it is a bit reworked though).
Will it fit? How can I make it fit if the locating rings don't work?
My heads inlet looks like this : https://www.facebook...46&l=b5f3b64a84
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 20 June 2014 - 05:50 AM
link not working for me
#3 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 20 June 2014 - 06:31 AM
you don't need to use the rings.
#4 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 09:02 AM
But how do you line it up then?
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 20 June 2014 - 10:16 AM
How much movement do you have between the manifold and the fixing studs ?
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 20 June 2014 - 11:59 AM
You can port match the manifold to the head if you want super-accurate alignment.
Do it with the carb/carbs off. Align them as aligned as an aligned thing can be, then dowel it so it's always pefectly as aligned as a perfectly aligned thing can be! You just need to be willing to drill a little hole or two through your inlet and into your head's gasket face.
It's not an issue on my new inlet, the ports align pretty good and there's very little room to get it wrong as the holes in the manifold aren't massively oversized. My locating ring seats in my head are long gone as it's been ported....so I've gone way off topic here.
#7 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 12:49 PM
Around 1 finger :P
Is there any chance to hit a water/oil gallery in this way?
The fun fact is that my balancing tube rests on my exhaust manifold, so I think that I cant really get it wrong...
I'll await your answer about the dowel, and I probably need to get the engine out to do that? :P
#8 Ethel
  • 26,040 posts
Posted 20 June 2014 - 01:07 PM
I don't find it an issue fitting with the locating rings, fit them to the manifold, you can use loctite, and fettle them to be a slip fit on the gasket and head.
If you don't use them you can trace the outline of the manifold onto the gasket, to give  the best fit, before assembly. Having a step can be beneficial to reducing flow reversion if it's the right way round.
#9 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 01:25 PM
cant fit them into the head sadly.. Its tigh tthough, maybe with some filing .. then again, I dont know if that would hurt flow :P
I could 'Shorten' the rings to make them fit, that wouldn't make a big difference I think, as my inlet trackt narrows anyways... Don't know fure sure if this would hurt though (again) .
#10 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 01:50 PM
Could I modify it by enlarging the ports a bit in situ?
Would use something like this, but don't know how it's called :
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2014 - 01:55 PM
Your engine would eat all the grindings, not recommended the stud to manifold slots are usually plenty good enough for a fitment of the inlet, after all thats what your left with when the heads been worked on as Cpt MW and Matt mentioned above
#12 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 01:59 PM
Or something like this? http://www.amazon.co...l/dp/B00553UNOU
#13 Dusky
Dusky
  • 5,322 posts
Posted 20 June 2014 - 02:00 PM
But it doesn't have manifold to stud slots :P
Edited by Dusky, 20 June 2014 - 02:03 PM.
#14 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 20 June 2014 - 02:03 PM
It's got half a hole on each side of the flanges though. Offer it up to the head and see how little movement there is when it's fitted.
They normally line up pretty accurately
#15 Ethel
  • 26,040 posts
Posted 20 June 2014 - 02:19 PM
If the rings won't fit the head, there may well be an edge that's going to be restrictive anyway. If it's only a small amount, file the rings on the outside.
