Not Firing On All Cylinders
Best Answer Stevelee10 , 25 June 2014 - 07:26 PM
Sorted. Seems I got a bit carried away with the problem. Turned out to be a bad plug on no1 but I still need to sort the ign issue as it doesn't run well with the ballast but runs great with a direct 12v.
So thanks for the help Go to the full post
14 replies to this topic
#1 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 07:13 AM
ive just refitted my engine to my mini and now its not firing on all cylinders so now im confused as i have not touched anything,apart from remove the carb for fitting it into the car. engine was running great on my garage floor. does anyone have any suggestions?
running on garage floor
and in the car
#2 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 25 June 2014 - 08:18 AM
firing order correct?
#3 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 25 June 2014 - 08:52 AM
Would it not then only fire on 2?
#4 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 25 June 2014 - 09:18 AM
By the way i haven't watched the video yet.
#5 ArneBrys
ArneBrys
  • 16 posts
I would go over the complete ignition system.
Check the plugs and leads (firing order).
Check the distributor cap and rotor for corrosion.
#6 stevelane
stevelane
  • 664 posts
Posted 25 June 2014 - 09:22 AM
Coincidentaly have just started a similar thread myself as I have no firing in cylinder two yet there seems to be a good spark and compression so will be watching this
#7 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 11:36 AM
OK. Well I have been over the ignition. Plugs, leads , Rotor and cap are new and ok. But what I've just noticed is that the loom is ballest ign but I've got a 12v coil. So maybe that it's the cause of my issues. Gonna try giving the coil 12v see if that improved things.
#8 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 11:37 AM
If it's not that think I'm stumped since it was running fine before I fitted it to the car
#9 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 25 June 2014 - 12:04 PM
checked the valve clearances?
#10 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 25 June 2014 - 01:24 PM
Are you running points or elec ignition?
#11 Dusky
Dusky
  • 5,322 posts
Posted 25 June 2014 - 03:56 PM
Firing order looks like it is 1 3 4 2 on your engine...  ( it is a bit dark on the video though)
Should be 1 3 4 2
#12 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 04:10 PM
Well the valve clearance was ok. Cant see how that would change moving the engine 6ft and I'm on points ign
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 June 2014 - 04:26 PM
9v ballast feed to a 12v coil produces a very weak spark, do the 12v feed and see how it works then.
#14 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 07:26 PM   Best Answer
#15 Stevelee10
Stevelee10
  • 120 posts
Posted 25 June 2014 - 07:37 PM
