Hi I have notice on my mini on rear near subframe mount there is a crack on the sill going down I think it has had over sills on in the past but why has it got a crack?
Sill Problem
Posted 28 June 2014 - 03:55 PM
Posted 28 June 2014 - 04:15 PM
Can you post a picture?
Posted 28 June 2014 - 04:37 PM
SAM_1126.JPG 59.44K 57 downloads
here you see the rust mark going down is the crack best I can get of the picture
Posted 28 June 2014 - 04:39 PM
Looks like stress on the sill form the subframe. Perhaps the heel board subframe mounting plate hasn't been welded to the inner sill strongly enough. Either that or it's rusted through.
I would have that oversill off and have a poke around.
Ben
Posted 28 June 2014 - 04:40 PM
That doesn't look too good, it has over sills and it may be that the heel board is flexing (where the subframe mounts) due to the rot underneath.
Have a look in your companion bins for rot.
Posted 28 June 2014 - 04:41 PM
Ben
Beat me to it, (although we both agree)
The oversills need to come off to reveal the true horrors of what is beneath
Posted 28 June 2014 - 04:42 PM
That heel board does look suspect to me.
Hope it's not major surgery time
Posted 28 June 2014 - 04:43 PM
It is major surgery time
Posted 28 June 2014 - 04:48 PM
As i feared mate
Posted 28 June 2014 - 04:49 PM
As i feared mate
Doesn't look like it is safe to keep using. Last thing you want is to loose the rear subframe while driving along!
Well it probably wouldn't happen but as it weakens,you will get more slop and then it will start bending and twisting things back there, especially if there is a load of rot behind that sill
Posted 28 June 2014 - 05:02 PM
yeah I thought it may be stress from the subframe new heel board panels and sills needed then thanks anyways yeah I'm not going to use it till its fixed
