Using Welding Rods For Panel Gaps?
Best Answer Carlos W , 06 July 2014 - 10:52 AM
your ebay link is no longer available for alternatives to welding rods. do you know what they are called and I will search them.
Thanks for the advice will try it
Try this one
http://www.ebay.co.uk/itm/300447498179
GAS WELDING RODS 3.2 C/COATED MILD STEEL CCMS CAR WELD
Go to the full post
9 replies to this topic
#1 96minimig
96minimig
  • 169 posts
Posted 06 July 2014 - 10:40 AM
hello
have seen in the guides about welding rods to tighten panel gaps. I have just reskinned the drivers door on my mini and found the gaps are all fairly good apart from the front of the door where it meets the apanel needs approx 3-4mm adding to the metal. i have tried running a bead a weld part way down the door to try it, but saw the welding rod technique.
forgive my ignorance but is it just a case of welding the rod to the door and grinding it to panel gap desired then finish with filler?
are any arc rods suitable obviously to the right thickness as seen on the guide?
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 06 July 2014 - 10:45 AM
I've just done this and the door hinge caught the door as the gap was big and took a bit of trimming of the hinge.
Don't use arc rods, I used these http://www.ebay.co.uk/itm/300447498179
I tacked them in place, then seam welded both sides, grind back, then a skim of filler.
#3 96minimig
96minimig
  • 169 posts
Posted 06 July 2014 - 10:49 AM
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 06 July 2014 - 10:52 AM   Best Answer
Try this one
#5 96minimig
96minimig
  • 169 posts
Posted 06 July 2014 - 10:57 AM
thanks again. Will give it a go. need to reskin the passenger door yet so will see how that side goes. eek
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 06 July 2014 - 10:59 AM
As slow as you can, keep it as cool as possible.
I did a bit of work around the lock on the other side too
#7 96minimig
96minimig
  • 169 posts
Posted 06 July 2014 - 11:03 AM
will be slow as dont want to warp the skin. I have had to shim the door to create the nice even tight gap on the lock side. and I had to gently persuade the frame to sit on the door seal so not to bad. So long as i get the hinge side right with these rods.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 06 July 2014 - 01:38 PM
If you go to bodywork paint and detailing there is a pinned how to thread there.
#9 96minimig
96minimig
  • 169 posts
Posted 06 July 2014 - 04:24 PM
As mentioned above sonik I have seen it cheers ;D
#10 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 06 July 2014 - 05:08 PM
I did the same on my clubman but tacked the metal rod onto the a panel instead of the nice new heritage doorskin. I felt there would be less potential warpage on the smaller a panel instead of the larger doorskin.
