Splitting Ball Joints
Posted 06 July 2014 - 07:22 PM
In the past I was advised to remove the lower one as well and let the extra weight help the job along but even this isn't working.
I have been bashing away with a fork type splitter and have bent two other scissor types.
The two hammer trick also hasn't worked.
Any advice?
Posted 06 July 2014 - 07:24 PM
Have you tried heat as well
Posted 06 July 2014 - 07:27 PM
stop hitting it like a girl.
Posted 06 July 2014 - 07:29 PM
Not yet, was hoping it was a last option as I want to get it back together as quick as poss and don't have a spare rubber cover. Was seeing if there was anything else first
Posted 06 July 2014 - 07:32 PM
Lol, how did you know??
Seriously though, the prongs on the fork splitter are taking a battering but no movement
Posted 06 July 2014 - 07:51 PM
Piece of 4x4 under the arm holding the weight of the car and batter it from the top
Posted 06 July 2014 - 08:04 PM
And it will still be useable after?
Posted 06 July 2014 - 08:23 PM
No, thought you were changing it, they are only cheap
Posted 06 July 2014 - 08:27 PM
I was hitting the side of the arm to release the joint, no luck, splitter fork, no luck, scissor splitter no luck.
I then got hacked off with it and a combination of the fork, a blow tortch and smashing like a looney they popped straight off, the second one then came straight off.
I would soak it up with some decent penetrating oil over night, and then get out there the day after and give it some heat, then smash it like you're trying to bend it and you should have some success.
Another way I've done it in the past is using a large carver clamp inverted and pulling outwards. You have to push against the driveshaft though and it's a bit fiddly. Just donk it.
Posted 06 July 2014 - 08:29 PM
And it will still be useable after?Piece of 4x4 under the arm holding the weight of the car and batter it from the top
No I'm not changing it, I'm trying to get the drive shafts out. If it comes to it I will smash it and get a new one but just up against a time limit so was looking for any ideas to get it out undamaged
You need a good quality scissor type like a sykes pickavant and a heavy hammer.buy cheap buy twice!
Edited by HUBBA.HUBBA, 06 July 2014 - 08:33 PM.
Posted 06 July 2014 - 08:37 PM
Take the bottom one off instead
Posted 06 July 2014 - 08:48 PM
I have, but it doesn't seem to give enough movement to pull the driveshaft out of the point joint that I need
Posted 06 July 2014 - 09:01 PM
unless your splitter is made of chocolate then it's just a case of hit it harder.
what hammer you using?
Posted 06 July 2014 - 11:56 PM
You said the scissor type splitter did not work. For the most effect, loosen the joint's nut but leave the nut on the stud to protect the threads. Put put a piece of scrap metal on top of the nut so the scissor jaws are parallel or close to parallel. Tighten the scissor's screw ridiculously tight. When you feel like it is going to break... take a hammer and strike a blow on the top of the scissor jaws (not on the screw). This will introduce a mighty shock while the joint is under pressure. Sometimes the scissors will work without the hammer blow, other times it is the only way to get a joint to pop apart.
If that fails to work, leave the scissors on the joint (fully tightened) and add heat . While adding heat, tap the scissors where you did while things were cold. A series of lesser taps with the heat should pop the joint free.
Strike at the red arrow in the picture linked below. (Sorry, I found the pic on the web and it is an attachment on another forum... not a direct picture link).
http://www.bimmerfes...=1&d=1306404981
Edited by dklawson, 06 July 2014 - 11:57 PM.
