Why Didn't I Buy Engine Mounts With Captive Nuts!
41 replies to this topic
#16 adam_93rio
adam_93rio
  • 3,271 posts
Posted 10 July 2014 - 10:19 PM
I don't understand why it matters that they are a metric thread though?
It doesn't matter, Adam, it's just that in terms of best engineering practice it is good to keep what were Imperial threads as Imperial threads and the spanner sizes as original.
Having said that I do have a few metric threads on my 'S', namely with the Riv-Nuts and socket head screws holding the additional instrument panels in place and the ones used to fit the lamp steady straps. Both are M4, but are for additional to original.
But of course, the Rover idiots mixed threads, most noticeably on the braking system with 3/8" UNF at one end and M10 Fine at the other (you couldn't make it up!).
I was thinking you might of said it as if the metric threads weren't as strong or something like that.
And I have a rover late carbed mini so I'm used to just having a mix match from the factory anyway
#17 Scoop77
Scoop77
  • 508 posts
Posted 10 July 2014 - 10:20 PM
It's just me but I prefer to drop them in from the top but with nylocks I suppose it doesn't matter.
Mine is a '94 Pete so I'm guessing mine will have the mix of threads being a Rover?
#18 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 10 July 2014 - 10:21 PM
Those captive nut ones are terrible to use, the way to line the holes up easily is to put a screwdriver in and move the mount a bit til it lines up properly. You can't really do this with the captive ones for risk of damaging the thread, which is really difficult to not damage when putting the bolt in anyway.
Surely taking the radiator off is a lot easier than farting about for ages trying to get the bolt through?
Mine have been through the opposite way before and with locking nuts never came loose
The rad was out when I was doing this. You need hands the size of a five year old for that one!
Or long fingers ;)
I just went out and looked at mine and I've still got the bolts through from the bottom, so it was always just a case of putting the nut on, for which I normally put the but in the ring end of a spanner with a bit of insulation tape on so it doesn't fall out
thats the way I always did it on the a series lumps ... insulation tape or even masking tape wrapped round a smallish half inch ring spanner - line the holes up from the outside with a phillips, drop the bolt through from the inside with the help of the taped ring spanner.  Glad to see the old school solutions are still in use.
#19 Scoop77
Scoop77
  • 508 posts
Posted 10 July 2014 - 10:26 PM
Duct tape I have. Will try this next time. I don't have a welder yet Pete.
#20 Cooperman
  • 23,332 posts
Posted 10 July 2014 - 10:29 PM
I've got a little magnetic 'gizmo' which clips onto a ring or open-ended spanner and holds a nut in place. Magic bit of kit, but hardly ever used now.
As above, I always put the bolt in from the outside, but now I always weld the nuts onto the mounting.
I was wondering if the nuts could be put in place with JB Weld or Araldite Steel adhesive. After all, it is only to locate them whilst the bolts are started. But then it would not be possible to line them up with a thin Philips screwdriver as they would break off
Edited by Cooperman, 10 July 2014 - 10:32 PM.
#21 Scoop77
Scoop77
  • 508 posts
Posted 10 July 2014 - 10:32 PM
What is this gizmo? Can we have a pic?
The JB weld idea could be good.
I think I'm gonna have a play with my variation on the width of the mount.
Edited by Scoop77, 10 July 2014 - 10:47 PM.
#22 Tupers
Tupers
  • 4,157 posts
Posted 10 July 2014 - 10:45 PM
I use one of these to drop the bolt down through then engine mounts. There's definitely a knack to getting the bolts in, it's just one of those things that's never super simple.
#23 cmonson
cmonson
  • 28 posts
  • Local Club: MOASF
Posted 22 July 2025 - 10:16 PM
I know that this is an older thread.
I kind of like the engine mounts with the captive nuts.
I just put some short studs in the mount to use as locators for the holes.  I ground off the exposed threads of the stud and put a small taper on them.  just a little wiggle once the engine is down and they just slide in.
Once the engine is in pull the studs and put in the bolts.  I opened up the holes in the subframe a touch too - helps with the wiggle to align everything.
All in all it works pretty good.
#24 nicklouse
  • 18,719 posts
Posted 22 July 2025 - 10:24 PM
They are total *******. Bolts fitted incorrectly and when the nut captive fails you are in a world of pain.
#25 Spider
  • 15,198 posts
Posted 22 July 2025 - 10:48 PM
Can we come back after you try to get the bolts out next ?
Fitting the bolts the way the factory did really is a piece of cake - with the right tool,,,,,
#26 cmonson
cmonson
  • 28 posts
  • Local Club: MOASF
Posted 22 July 2025 - 10:54 PM
For what its worth I was a little aspersive to use them at first.  but then talked with no less than 10 people and they all loved them.  Maybe you just got a bad set when you tried to use them.
#27 cmonson
cmonson
  • 28 posts
  • Local Club: MOASF
Pulled the engine last night.  No issues
Edited by cmonson, 22 July 2025 - 10:56 PM.
#28 Steam
Steam
  • 836 posts
  • Local Club: Victorian Mini Club
Posted 23 July 2025 - 12:01 AM
The mounts with captive nuts are a total PITA. I spent way too much time screwwing around with them last time I did it, ended up fitting normal ones after the frustration got the better of me.
Thay may sound like a good idea but in reality they make an already hard job near impossible.
#29 Spider
  • 15,198 posts
Posted 23 July 2025 - 03:19 AM
I can see you think you like these and sorry, I should have included there 'after they have been in a while (which includes driving it a bit etc)' give it say 6 - 12 months,,,
For what ever it's worth, I was manufacturing and retailing this type of mount back in the 80's but dropped them from the range after 2 years and too many bad experiences.
#30 DeadSquare
DeadSquare
  • 3,205 posts
Posted 23 July 2025 - 05:46 AM
For 60 years, I have been welding some 30mm long tags of 1/4" round bar (Used to come from the nails in the ashes of burnt pallets) to the top of the setscrew, not like a T but like an L.
I push my welded tag into a bit of rubber petrol pipe and use the pipe, as per the dining fork, to insert the setscrew through the engine mount and subframe.  Having lightly screwed on the nut, I pull off the rubber tube and the tag saves trying to get a spanner on the head of the setscrew.
