I finally got around to pulling out my slipping clutch. Pressure plate and disk look ok, with the flywheel side of the disk showing wear only on the inner 1/2 of the material. The flywheel friction surface is beveled and has some small cracks. Question is, what is the service limit for machining the flywheel? I would just replace it, but Mini Spares looks to be backordered on the Verto flywheels.
Verto Clutch Questions
GenLightening
, Jul 14 2014 03:41 AM
1 reply to this topic
