What can i do about this? Is there any way of rebuilding the seam?
Cheers,
Josh
Rusty roof gutter
Jobu
, Jun 23 2006 05:44 PM
4 replies to this topic
Posted 23 June 2006 - 05:44 PM
Posted 23 June 2006 - 07:24 PM
Well there is a proper way and a not quite so proper (bodgeish) way.
The proper way is to cut out the rusty sections leaving straight edges of good metal and to weld-in new metal and grind welds to shape.
I have seen gutters repaired with a chemical metal type product. As the flange is curved, the inside of the curve can be built-up a bit to provide some strength by overlapping onto good metal. Since the inside of the flange should have a liberal application of seam sealer anyway the repair isn't very noticeable.
Posted 23 June 2006 - 10:10 PM
Hi
If it were me, i'd go and cut a section of a mini in a scrapyard, cut the rust out on yours, and repair.
Posted 23 June 2006 - 10:15 PM
Hi
Job's a good un
Posted 23 June 2006 - 10:31 PM
Thanks for the advise, i've been offered some gutter cut from a scrap shell just going to have a measure up tomorrow so they can send it B)
