Hi all, I got 2 questions,
first :
Any Advice for a needle starting point?
998cc- AEG 643 camshaft ( 288°), worked head, Double HS2 carbys with substack & K&N cone filters.
Got AH2 atm but is a bit rich I think..econd : when installing a fixed needle, how deep do you have to push the needle? Do you have to level the thick part o fth eneedle with the carb piston? or do you have to push the needle all the way in?
Cheers!
