Spi Air Intake Sensor Fault
23 replies to this topic
#16 FlyingScot
FlyingScot
  • 2,664 posts
Posted 21 July 2014 - 09:43 PM
Wiring diagrams are available online :-) MEMS itself is fairly robust and SPi minis are just minis after all (wiring by the lucas the prince of darkness...)
FS
#17 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 22 July 2014 - 01:47 PM
FYI-
I received an email from Autotek who have my ECU ( I only posted it on Friday, from Sweden)
The fault:
"This Engine ECU has been tested several times and found to be faulty. The internal power supply circuit has been overloaded and the 5 volt output rail has failed. Refurbishment is required."
the damage - 238 pounds
#18 humph
humph
    How bad can it Be?
  • 1,108 posts
Posted 22 July 2014 - 02:42 PM
I used these guys when my ECU needed repair, syptoms eratic idle, http://www.ecutesting.com/. If you follow the link on the left "ECUs explained" there is a section on common problems with Rover MEMS ECUs. Service was quick and no problems since, seem to recall that I paid a lot less than £238 too.
Good luck with it, chasing faults around only to find that it's the ECU is frustrating to say the least.
#19 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 22 July 2014 - 02:57 PM
I didn't think the price was too bad.
Connor: for reference my ECU is MNE101170
#20 humph
humph
    How bad can it Be?
  • 1,108 posts
Posted 22 July 2014 - 03:52 PM
In fairness neither do I, it wasn't a criticism. My repair may well cost that these days, it's 4 years since mine was done. I chose a repair becasue the other option was £100 on ebay for an untested used replacement, which didn;t seem like much of a bargain if later found to be faulty.
#21 FlyingScot
FlyingScot
  • 2,664 posts
Posted 22 July 2014 - 04:20 PM
Connor: for reference my ECU is MNE101170[/size]
Cooper SPi with immobiliser sequence. (Needs matched 5AS and keyfob )
FS
#22 connorj
connorj
  • 11 posts
Posted 23 July 2014 - 01:20 PM
FYI-
The fault:
Thanks alot! This seems like exactly the same as mine. My ECU is MNE101150. I think yours is slightly uprated from mine but I can imagine they use roughly the same layout.
Saw Autotek first but after looking on this site a lot of people recommended ecu doctor which is £35 for test and £140 for repair + parts, and wehn repaired by them you don't have to pay for the test. I expect mine will end up costing around £238 too no doubt!
Also, found some replacement MNE 101150 ECUs the same as mine, I know that the ECU has to be coded in but was wondering whether this would be a cheaper option if the ECU was only £50-75 second hand?
#23 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 July 2014 - 01:47 PM
I guess they will all work out the same. remember my price include signed form slivery back to Sweden too.
If you go for a second hard ECU, could you guarantee it was good?
#24 connorj
connorj
  • 11 posts
Posted 23 July 2014 - 02:10 PM
I suppose that is the risk. Probably better just to bite the bullet and pay for ECU repair, at least I know the rest of the ECU is good
