When fitting a 12G295 head, or any replacement head really, it is essential to measure everything, do the compression ratio calculations, then have the head deck machined to give the required compression ratio.
A 12G295 head was designed to work with the original Cooper raised D-top pistons which put the compression ratio up. With currently available pistons, dished or flat top, a fair amount needs to be skimmed to get the comp. ratio correct, but without measuring & calculating it is impossible to say how much.
This is not something which can be 'guessed, it has to be done properly.
