Water Bottle Bubbling Up When Stopping ? 03 Cooper S
Posted 27 July 2014 - 05:09 PM
Posted 27 July 2014 - 05:25 PM
Posted 27 July 2014 - 05:26 PM
Posted 27 July 2014 - 05:32 PM
Whats the flow through the Radiator like, could be not efficient in the hot weather due to age or build up of particules causing it to run hot, its either boiling the water hence the bubbling or there is a compression leak, I'd do a sniff test to rule out combustion gasses in the cooling syatem, then look at the radiator and back flow it. Does the cooling fan come on when its this hot?
Posted 27 July 2014 - 05:38 PM
Posted 27 July 2014 - 05:56 PM
Posted 27 July 2014 - 05:57 PM
Posted 27 July 2014 - 05:59 PM
Posted 27 July 2014 - 06:05 PM
There are a number of water bottle and pressure cap failures so it might be worth changing those, don't forget if you cannot pressurise the rad system the coolant will boil at 100 rather than say 120 deg.
Posted 27 July 2014 - 06:07 PM
what is the rad / expansion cap like , is it leaking early letting the water boil ? edit ^^ beaten to it ^^
is it possible a hose has collapsed inside - but looks ok outside - so restricting flow somewhere ?
I would also flush thru a few more times - then put in a good mix of antifreeze/coolant
PS we are a mini classic site - but it don't really matter that much - we all like cars
Edited by sledgehammer, 27 July 2014 - 06:08 PM.
Posted 27 July 2014 - 06:13 PM
Posted 27 July 2014 - 06:14 PM
Posted 28 July 2014 - 09:35 AM
Don't forget the Minis are toys for most of us, and were involved in mainstream day to day cars and cooling systems hanen't changed in basic operation so its common advice what ever the year, I'd be back flushing and checking the rad as you suspect.
Posted 28 July 2014 - 01:48 PM
These engines are like that, the engines pressurise the coolant... Something to do with crank case pressures
Posted 28 July 2014 - 03:07 PM
erm... I dont think that is correct at all. Crankcase pressure is not related to a presurised coolant system.......
