Posted 28 July 2014 - 12:15 AM
Posted 28 July 2014 - 08:32 AM
Your standard wiring if in good condition can take the upgarde to 55w bulbs now, your sealed beams were 45wx2 and drew 7.5amps, 2x 55w bulbs will draw 9.16amps, by all means fit relays to take the load off the standard switches (4 off), but there are hundreds of cars which had sealed beams running around converted to 55w Halogens without issues.
Edited by KernowCooper, 28 July 2014 - 08:33 AM.
Posted 28 July 2014 - 09:11 AM
ah, I thought the relay set-up was a must Dave. My wiring and connectors are all good and clean, I'll slip the 55's in and try them and keep monitoring the switch then. Bring on the night! ![]()
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
