I'm using E3 needles with red springs now.
I thinkt hese needles are suitable But I have some problems now, first problem is that he runs lean I think ( picture of a plug attached) so that will just be a case of enrichening the mixture and see how it goes.
Second : When I put my foot down the car doesn't react instantly, I have to wait a bit until he starts to go faster. Would this be caused by the lean mixture? Or should I try some lighter dashpit oil ( 20W50 oil in it now) , or maybe even blue springs?
Mini Stuttering, Weard One
#16
Posted 04 September 2014 - 09:12 AM
#17
Posted 03 December 2014 - 07:41 AM
Fitted the standard air filter box and the car went better. This probably suggests that I need a needle that is even richer?
Can I just fit swinging needles in my HS2? Or do they make every needle fixed and swinging?
Also : I never used copper washers on my brake servo to manifold connection, could this have caused an airleak?
#18
Posted 03 December 2014 - 10:13 PM
You really need washers on the servo connection to ensure its airtight
#19
Posted 03 December 2014 - 10:28 PM
Ordered some toghether with my gearbox rebuild parts :)
I hope that was the caue of my problems.. ![]()
