Ooper S Works Uprated Fuel Pressure Regulator
29 replies to this topic
#1 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 03 August 2014 - 10:42 AM
hi guys, anhone uprated their fuel pressure regulator (mpi) as with the cooper s works. Have spoken to a few companys who can supply one, apparently its just a case of squishing the current one, or are there any on the market good to go?
cheers
craig
#2 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 04 August 2014 - 11:45 AM
I have one going spare as I have fitted the sc kit.
Fitting instructions looked simple but I've no idea how good it is. to be honest the mpi setup is crap lol.
#3 Fossy313
Fossy313
  • 583 posts
Posted 04 August 2014 - 02:29 PM
That's the plan to go as well jake I think but just wanted to see if there was some way of adjusting mine if it needs to be
#4 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 05 August 2014 - 09:16 AM
Get saving buddy, it's well worth it.
My mpi was running 72 bhp (s works 90kit plus sw5) and note I've got it running 91! Pills nicely through to a 6800rpm peak part is at 5850 up from 5200.
God luck
#5 sirjakethebrit
sirjakethebrit
  • 87 posts
*now
#6 Fossy313
Fossy313
  • 583 posts
Posted 05 August 2014 - 06:49 PM
Awesome mate, that's the way forward then I think!!
Thanks for the help,
As for your fuel pressure, is it the power boost, are u selling, i may be interested, however I'm likely to fit the head etc first and see how the fuelling is first...
#7 PlugExploits
PlugExploits
  • Just Joined
  • 137 posts
Posted 05 August 2014 - 07:53 PM
I have the kit waiting to go on my spi. Did your alarm and immobiliser still work when fitting sc kit?
#8 tony kenobi
tony kenobi
  • 381 posts
  • Local Club: Mini Owners Club of WA
Posted 10 August 2014 - 12:56 PM
Fuel reg is not needed unless you fit an uprated head.
Some people say they aint needed, but it made a difference to my mpi after it was fitted. Better to fit a gauge to it so it leaves adjusting it better/easier.
Theres some cutting of the fuel line to the injectors to do and rerouting of fuel lines etc. Just a pain with everything in the way!
Just don't jump at the words 'power boost' it's only valuable if other components are fitted and setup properly.
#9 Fossy313
Fossy313
  • 583 posts
Posted 10 August 2014 - 01:33 PM
I'm fitting it because of my head as long as the engine runs lean, any ideas do the gauge u connected and how I hooked it up mate?
#10 tony kenobi
tony kenobi
  • 381 posts
Posted 10 August 2014 - 02:12 PM
Hi there, check this topic i started a few years ago...
http://www.theminifo...-rebuild/page-2
But issue is I've lost the photos attached to the conversation. But read through it, some of it might make sense.
This is mine fitted to my MPI...
 14896262583_e9c2e9da1c_c.jpgP1030054 by Tony Kenobi, on Flickr
It should have come with directions for installation. The gauge was similar to this...
there is a threaded hole in the regulator to screw one of these in.
#11 Fossy313
Fossy313
  • 583 posts
Posted 14 August 2014 - 02:26 PM
thats perfect mate, any chance of taking some pictures of what fuel lines you have cut and where the pipes go to?
a gauge it is for me as well i think!
#12 Fossy313
Fossy313
  • 583 posts
Posted 14 August 2014 - 02:27 PM
your engine bay looks mint to mate, any chance of a look?
#13 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 15 August 2014 - 07:11 AM
Where can I get and adjustable one like this with a gauge?
All the ones I see are a fixed pressure.
Also dose the increased pressure not mean that apart from the top of the revs the car runs rich?
#14 Fossy313
Fossy313
  • 583 posts
Posted 15 August 2014 - 07:54 AM
not neccessarily, its depends how your engines runnning, mine seems to be running slightly lean from my maniflow system...which means a fuel pressure regulator will work well, go to minisport minispares and type in power boost valve(goochy name for fuel pressure regulator) the gauge can be bought seperate.
#15 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 15 August 2014 - 01:45 PM
Well mine is a 1330 now but only runs lean after 5k RPM do dont rag it so rarely go over 5k. I would just like to know it has enough full if i do rev it to the stops from time to time, but then i don't want to over rich the lower running...
Whats the stock fuel pressure?
Edited by Ruckus, 15 August 2014 - 01:46 PM.
