I believe so. There must be a vacuum for it to work correctly, and the pressure varies between 0 and set limit (e.g. 3.2 bar) but it won't exceed the limit no matter how hard you push the throttle.
I'm not an expert with this, the knowledge I have is based on the info that I have read and from trial and error
There seems to be wide acknowledgement that modified mpis (both minis and MGs) suffer with lean fueling at top end and this seems to be the only option to help stabilise and even out the flow rate across the rev range.
I haven't noticed any major draw backs regarding mpg. Although I did plumb it in round the wrong way once meaning unused fuel wasn't being returned to tank. This was causing black spots to be blown out my exhaust from over fueling. Don't think my CAT or lambda liked that either but I've corrected it now and all seems well
Edited by jamesmpi, 17 August 2014 - 04:07 PM.
