Windscreen rubber fillet
Posted 26 June 2006 - 09:32 AM
Any tips on how to do this, preferably with out using a potential paint wrecker?
Posted 26 June 2006 - 11:53 AM
Guest_Zenob1_*
Posted 26 June 2006 - 12:15 PM
Good luck and don;t give up !!!
Z
Posted 26 June 2006 - 12:31 PM
for instance not vaseline as it is bad for rubber but KY jelly isn't so that is worth a shot surely.
No puns were used intentionally in the making of this reply (apart from the ribbed one)
Posted 26 June 2006 - 01:00 PM
Posted 26 June 2006 - 01:25 PM
Posted 26 June 2006 - 04:11 PM
I would not use WD-40. WD-40 and rubber parts don't always get along. I don't know what grade of rubber is used for windscreen seals. However, in industry a common problem is that factory mechanics will apply WD-40 to sticky air cylinders that commonly use Buna-N (nitrile) seals. The cylinders work great for a few hours until WD-40 attacks the seals causing them to fail. Again, I don't know what windscreen seals are made so I don't know that WD-40 would attack them... I just wouldn't gamble.
As silly as it sounds, the KY suggestion would certainly be safe based on material compatibility and "no salt".
Posted 27 June 2006 - 06:04 PM
Makes sense does it not?
oh, and i hate the job
Posted 27 June 2006 - 06:16 PM
Posted 17 May 2007 - 02:14 PM
Anybody got a pic of the tool used from Minispres ????
Can't find it on their website
Posted 17 May 2007 - 02:21 PM
Edited by Matrix, 17 May 2007 - 02:22 PM.
Posted 17 May 2007 - 03:09 PM
If it's going that badly, apply some watered down dishwashing liquid to the rubber where the locking strip goes. This will help you slide the tool through the channel to open it while inserting the locking strip.
Never use washing up liquid!
The high salt content eats away at any metal it comes into contact with and will rot the Claytonrite rubber.
Use glass cleaner.
Gav
Posted 17 May 2007 - 03:44 PM
washing up liqued is fine for inserting the filler strip and if you are worried about all that salt in it why not just hose it off when you are finished.
having replaced 100s 0f windows with claytonright rubbers i have never had to use a lubricant so maybe its the way you are using the tool is wrong.
Posted 17 May 2007 - 04:12 PM
Dan has posted similar warnings about not using dish washing liquid because of its salt content. I'm in agreement with Midridge2. I don't see this as a problem based on the amount of other salts our cars see. Also keep in mind that we're talking about applying the lube to a plastic locking strip and a channel in the rubber gasket. We're not talking about lubing the body opening.
Regardless, for those who want an alternative without salt, I've had another product suggested to me. Some swear by "personal lubricant". In the U.S. this would mean "K-Y Jelly". I don't know what comparable products are available in the U.K.
Posted 17 May 2007 - 08:15 PM
