HI,
Ive been replacing the driveshafts on my mini.
How do i refasten the two ball joint nuts holding the front hub in place?? They just keep spinning.
Cheers, Adam
Swivel Hub - Ball Joint Nuts
afswift
, Jun 27 2006 09:34 PM
1 reply to this topic
Posted 27 June 2006 - 09:34 PM
Posted 27 June 2006 - 09:51 PM
you need some weight on the arms. lean on the top of the hub and it should force the taper on the bottom joint, then stick a jack under the bottom joint to do up the top one (that'll put the wieght of the car on it., so be a bit careful when yanking on things)
