Painting Over Epoxy
Posted 23 August 2014 - 08:22 AM
Posted 23 August 2014 - 08:51 AM
normally you have 36 hours time but it depends on the manufacture. so you have to read the instructions to take the right answer.
for example i am using spies Hecker 4500 epoxy and you have 24 if you use it as wet on wet
Posted 23 August 2014 - 09:43 AM
So as long as its within the window before its cured it does not need flatting / keying?
The Jotun 87 is 10 Hours Surface Dry, 7 Days Cured. It also states Minimum to Re-Coat 10 Hours, but I have been told its OK to spray more Epoxy or Top Coat a lot sooner than this, Epoxy straight away and other Paints in an Hour once its flashed.
Posted 23 August 2014 - 09:48 AM
