Sort of. Take the air filter off. If original, there will be an elbow on the carb intake. Pour the thimble of gas down the carb throat and start the engine. It is likely to do exactly like it did with starter fluid... fire for a few moments and then the engine will die. That means there is a fueling issue. It is likely to be the carbs. However, do not touch the mixture. Also do not remove them and send them back to the builder.. not without trying a few simple cleaning steps.
These should be HS2 carbs if original. Remove the fuel hose from the bowl lid, then remove the three screws holding the float bowl lid in place. Now lift the bowl lid off. The bowl should be about 1/2 to 2/3 full of fuel. If there is less fuel, the float valve is probably partially blocked or stuck partly closed. If there is more fuel in the bowl than that the valve may stuck open or the float may be partially full of fuel.
Assuming the float is not full of fuel, use spray carb cleaner through the fuel hose connection on the bowl lid followed by compressed air. Repeat several times. Make sure the float moves freely. With the float lid upside down, blow into the hose connection. The valve should be closed (no air coming out). Now flip the valve over so the float hangs down. Blow again into the hose connection. Now air should come through. Put this lid back, reconnect its fuel hose, then repeat this for the other bowl lid.
If the problem persists there could be a blockage in the jet or in the plastic tube connecting the carb jet to the float bowl. To address this, carefully remove the screws holding the carb suction chamber to the carb body. Lift the suction chamber and piston straight up and carefully place them on their sides. Use the plastic tube on a can of spray carb cleaner to blast carb cleaner down the carb jet and into the plastic tube. Work the plastic tube up and down into the jet making sure you continually flush the jet with carb cleaner to remove gum and varnish. Use some of the carb cleaner on a coarse cloth to clean the needle sticking out of the carb piston. Move the piston up and down in the suction chamber. With the screw in plastic cap removed, the piston should move up and down freely in the suction chamber. Finally refit the piston and suction chamber to the carb and top its dashpot with oil.
