Failed Mot On 2010 Mini - Co Emissions
7 replies to this topic
#1 Mark1961
Mark1961
    Starting My Mini Up
  • 2 posts
Posted 01 September 2014 - 11:41 AM
Hi,
My mini failed its MOT today (at KWIKFIT) and I urgently need to get it fixed by tomorrow am if at all possible.
It failed on headlight adjustment, which I can sort myself but more importantly it failed on CO emissions. Hoping for some simple and cheap advice to resolve without the expense of a new cat. I tried an engine improver after it failed and ran it for 40 mins at high revs up the motorway but it still recorded a fail on CO. Results as follows:-
Fast Idle CO: 0.22/HC: 66/Lambda: 0.993
Second Fast Idle CO: 0.26/HC: 58/Lambda 0.992
Second test after the run was still at CO 0.26
Any suggestions would be greatly appreciated.
Thanks,
Mark
#2 samsfern
samsfern
  • 5,243 posts
Posted 01 September 2014 - 12:10 PM
I might be wrong, but I'm sure when I was doing mots at my old work, the machine raised the limit to 0.30 for the co, after failing the first fast idle test....
#3 darkcat
darkcat
  • 398 posts
Posted 01 September 2014 - 12:17 PM
a quick service might help if its not been done for a while, plugs and air filter are most likely to effect emissions.
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 01 September 2014 - 12:24 PM
Plugs and air filter are definitely worth checking and replacing if necessary. If not, a bottle of Cataclean has never failed me, a bit expensive but it does work.
How does the car run?
#5 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 01 September 2014 - 12:25 PM
Check the air filter isn't clogged up at all.
#6 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 01 September 2014 - 12:54 PM
Kwif fit????? Id go elsewhere. The engine needs to be really warm for a good reading
#7 HarrysMini
HarrysMini
  • 3,352 posts
Posted 01 September 2014 - 01:06 PM
Yes, the CAT needs to be hot and fully up to working temperature to work properly. Usually the tester will warm the car up if it fails, but sometimes they don't.
#8 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 01 September 2014 - 01:29 PM
KwikFit.  Go elsewhere and I guarantee it wont be a problem.  Cowboys the lot of them.
