So I reversed from my driver and snapped the wing mirror off
Do I need to take the door card to get to the bolts?
Best Answer megamini_jb , 05 September 2014 - 01:31 PM
No, door card doesn't need to come off. The door mirror should have a little plastic cap underneath the base where you can access to undo them
The nuts are also accessible where the window is, so remove the chrome window strip on the inside of car and you'll see the nuts down in the door.
Go to the full post
Posted 05 September 2014 - 01:29 PM
Posted 05 September 2014 - 01:31 PM Best Answer
Edited by megamini_jb, 05 September 2014 - 01:36 PM.
Posted 05 September 2014 - 04:20 PM
Thanks, will save me taking the door car off and realising I don't need to!
Posted 05 September 2014 - 04:32 PM
Edited by megamini_jb, 05 September 2014 - 04:36 PM.
Posted 05 September 2014 - 04:41 PM
One bolt came out but the other just spins so i'll take the chrome strip off and have a gander
Posted 05 September 2014 - 09:45 PM
If you can get a flat screwdriver or scraper between the mirror and screw you should be able to keep the screw "tought" while unscrewing it and it should come out.
