What Is This Cable? & Other Indicator Issues
2 replies to this topic
#1 gazpoole
gazpoole
  • 30 posts
Posted 09 September 2014 - 09:32 PM
Name that Cable!
Please see photos attached or using link below..
https://www.flickr.c...57647017834078/
Under the passenger side front wheel..
I have one plug for the front indicator (Black plug with bits of red paint). All other light fittings (as far as I can see/work out) are plugged in and working.
I am left with one cable... Blue end (Green/Yellow & Black Wires) which I can't seem to find a use for?
Any ideas?
Other Issues
Not sure if related, but..
Symptoms
- New LED rear bulbs installed (direct replacement) - However, issues weren't instant!
- All bulbs lighting up when hazards are engaged at regular blink speed. (inc interior indicating lights)
- All correct bulbs working when using indicators but at double speed!
Any advice appreciated! Sorry if anything is under explained...
Thanks!
#2 jemo
jemo
  • 38 posts
Posted 12 September 2014 - 07:24 PM
Hi,
A bit of a guess, but the blue plug may be for the optional front spots and fogs - unless they are already present and fitted.
The indicator issue sounds a bit like an earthing problem - remember the hazzards are in part a separate circuit as they are fed from the battery - i.e. always available whereas the indicators need the ignition to be on.
J
#3 gazpoole
gazpoole
  • 30 posts
Posted 14 September 2014 - 10:39 AM
Hi,
J
All front spots fitted :( Thought of that myself... All plugged in and working correctly.
Never thought of the earth issue.. Will have to tear apart and have a look!
Thanks!
